Something wrong with my hydro force?
I'm Rick James
I roll with a 3ht LG heater and when I start prespraying after a few minutes, the HF is just spitting out steam with little to no prespray. It does it with my wand sometimes to, but not as bad.
From what I see the HF is working fine.
Brian R
Brian Robison
You're not supposed to use too much heat with an HF.
Brian is right, there are not designed to work with high heat. The dema valve won't draw chemical and you'll just spray water. you'll need to dial down your heat for it to function correctly.
I'm Rick James
Wow I never knew that, I used a HF with a salsa CDS and never had this problem.
Sounds like I may of blown the dema valve?
Is there a high heat HF? I really dont want to waste the time turning down my heater, I only prespray a few rooms ahead of me.
Brian R
Brian Robison
I've got a great option for you.....and Rich knows aaaaaaalllll about it. shiteatinggrin
I'm Rick James
Close my business and become a porn star?
Brian R
Brian Robison
Straight from the water spiggot for pressure and clear water....you can use an inline heater if it means that much to you.
I use this for backup if there is not a hose spiggot close enough
I use pressure washer type QCs to keep the flow "open"...Home depot or lowes
Same pressure washer QCs here for the same reason
No high heat version, I doubt it's ruined.
Mostly likely the steam was just not allowing the venturi action, once it cools down I think you'd be fine.
STAY AWAY from Brian!!! :p
I'm Rick James
Thanks for the tip Brian, gonna pass on that one. More work then turning down the heater.
Thanks guys for solving my problem.
Brian R
Brian Robison
lol...I hear ya.
Works for me though.
Don't tell Chavez.
