Speaking of wine soaked ball valves
Check this beauty out.
I got it at my Parker store for $26.
Culverco brand
Parker SS valves are $68. ( but 2000WOG)!
Carpet Cleaning Fool
Busted the male-male hex on mine after about 6 months. EZ-Out the broken piece, insert new male-male hex and 4 months later the damn thing is still holding pressure. I carry a spare in the van just in case.
I betcha it will go a year
2000 WOG's eh?
it's stamped 1000
are WOGs double PSI?
Water, Oil, Gass
BTW, a dude that works at Parker (right down the road from me) told me they pressure test at 3 times ratings
Mikey;
Here's a candidate:
Stainless Steel 1/4" FM Pipe
Short Handle for solution line
Steam Rated for the fire-breathers
Reinforced Teflon
Here's a larger stainless one rated for 800° that we use on our HX system.
R W
The HUGE handle would be a PITA at the wand. I currently use the small Parkers with the little yellow handles. They work well until you try to crank up the pressure for T&G work. Then the leaks start.
Some company out there, somewhere, has to have a decent valve that can take the PSI and the heat, and they aren't HUGE....
boazcan
These are the best that I found. Use 2000 psi on pavers and they last a long time.
read again there Nugent. The one I got is 1000, the Parkers are 2000.
How much Larry?
I haven't hunted in years and years.
i wasn't going to tell you this, but i went hunting this morning with some friends.
geeze you should of seen it.
The Pheasant jumped and flew past FOUR hunters lined up.
An EASY crossing shot at less than 30 yards.
all four blasting away at it's TAIL FEATHERS!
(them boyz need to shoot a little more often, me thinks)
I shouldered my trusty Remington and BANG LIGHTS OUT!
the rooster dropped like stone 25 yards in front of me.
he's ready to go in the oven now!
AND...I'll use the feathers to tie some flies and pester some trout! :mrgreen:
Predator Elite....
Blue Monarch
Dirk Wingrove
I haven't had pheasant in over 15 years. Sounds good. I need to drop some this year.
It won't happen though, I'm a terrible shot.
