Spraying Nozzles and Jets
NJ104
U.S.A
Juan
Maybe you all could give the answer or maybe there is a place to find this information. But I wanted to know what is the best angle and output of nozzles and T-Jets. is 90 degrees better the 110 degrees. and is the degree the width of the spray pattern ??? is it that 90 degrees is a smaller spray size verses 110 degrees ???
Village Idiot
better? this will depend on the jet height/area to be covered/number of jets
but yes the degree is the width of the spray pattern ....110 being wider than 90
Reactions: BIG WOOD and NJ104
Montana
Swani
What wand or tool are you looking for?
Talking about wands, especially for a portable, if you are using a twin jet wand like an AW29 or similar, most will use 11015 jets giving you a 3 flow. 110 degrees wide. 95 or 80 degrees will give you a narrower spread. Your portable can't power anything more than a 3 flow effectively.
Reactions: icleancarpetz
