spraymaster questions
joeynbgky
Joey
I had a few problems with it.. but they took care of it and sent replacement parts...
But i have turned my psi up to 400.. It seems to take to long to prespray... There is not good pressure like my HF.. How can i fix this?
Billy
BH
Have you checked the inline filter in the handle? This can cause low flow.
joeynbgky
Joey
yes..... they have sent me new QD because one was cracked. out of the box. and another one was as well which i replaced.. It just seems like low pressure
Art Kelley
You have to find out where the slow-up is. Take off the dema valve and run your spray, if it blasts solution, put on the dema and see if it blasts at that point, if not the dema is clogged. Take off the spray nozzle, could be slow there. Try a bigger spray jet, a flood jet.
what jet is in it??
and how the heck does a brass QD "crack"????
and TWO of them no less..... :shock:
joeynbgky
Joey
They said it must have cracked in the vice when they put it together.. but great CS
Jim Bethel
Jim Bethel
Just remember as soon as you start playing with larger jets, you are adjusting the flow on the dema too
