Sprinter question
Can you effectivly seal of the cab so you don't have to deal the the heat and stench of a slide in?
And where are people mounting the gas tanks to run non diesel units?
Brian R
Brian Robison
Cameron1
Yes. It comes from the factory with an installed Bulkhead. With a little caulking and linex you can get it airtight.
The new Sprinters made by Mercedes are light years ahead of the old Dodge models. You will be impressed by the quietness of the motor and the space to haul whatever your unique capabilities are.
Shane T
Shane Tiegs
I like the factory installed bulkhead. This is what I did in my 04 Chevy extended van. Its painted white and the center portion can removed from the cab side. I love being separated from the back of the van especially in the summer.
L
lance
Shane, great look on the inside of your van. You don't see many vans with two water-wells in them. Very clean install.
How do you store your hose and supplies? Got any more pics?
daniel@procarpet
Mike you should just convert your V to a slide in box truck.
Yep....rip out all the V parts and put them on a shelf and wait for the highest bidder....take it down and have the huge hole welded back up and all the others fixed.....treat it...coat it...rhino line it...and pick out what you want to put in it...
Walt
I don't feel the heat or smell anything. Rides better than a box truck. Smaller engine but powers up a hill much faster as well. Cruises at 75mph loaded with no problem.
Becker
God, I feel like such a hack when I see the inside of others vans..
Brian R
Brian Robison
I'll show you the back of my truck and you'll feel like you're on top of the world.
Becker
Do it, I could use a boost..
Brent never gave me props a few weeks ago when we work togther..
Walt, I assume you need to stand in the truck to reel in the vac hose?
Does that G59 really dual wand? two wands, 14 inches with 300 feet out?
Brian R
Brian Robison
I've been too ashamed to even take the pic. lol
Maybe tomorrow because I have to get it ready for next week anyway.
Walt
I stand in the truck out of the rain. It has a foot pedal switch for the reel. Works like a dream - one hand to guide the hose, the other to towel off the hose as it reels in.
It will hold 14 inches on two wands no problem. I've never run more than 250 on one and 200 on the other at the same time. That's all the hose I carry. So I can't comment on dual 300 ft runs.
no, I meant two 150 runs..
How does the 59 compare to your old Vortex on a situation like this?
SMRBAP
Anthony
I wish I'd have known a week ago, had a factory steel wall that I just drilled out and fed to my dumpster. I use console water tanks to keep the weight dist. as even as possible, so I toss them, 3 so far - sorry man.
I just bought another, I have a tech driving it in from NY as I type this, I have another in TX I am picking up next week, and will need one more. All are/will be the super tall models. If I end up with another, It's yours if you want to handle the shipping cost.
Also on the fuel tanks, I use marine grade inboard tanks, 12 gal. units from overtons. They provide for return lines (if EFI), you can buy vent kits, you can buy exterior fillers and mount it through a wall, etc. Lots of options.
I strap them down inside the van, vent them to the underside, fill from the inside, and I do have a ground strap. Some folks on the boards have raised issues with this, I'm comfy with them installed the way they are - I have had 4 vans set-up this way for about 6 years, one was in a pretty bad accident, zero issues. You just have to be smart about the fuel line type, how you route it, etc.
I haven't seen a universally DOT approved secondary tank for these vehicles, however there are a few non-approved out there, but they are not cheap, $1400-1500 pre installation - and where they locate them, a very minor accident could = a boooooom. I'd stick with what I had even if those tanks were the same price as the marines I use.
http://sprinterstore.com/specialty_parts.htm
Heres a post with some pics of one of my older sprinters
viewtopic.php?f=1&t=28230
SMRBAP
Anthony
Also let me know what year sprinter you have/are getting - I can pm you a few sources for maint. parts and even used parts super cheap.
Walt
http://mikeysboard.com/forum/viewtopic.php?f=1&t=28230
They want 3k for that tank with side fill installed. Apparently it's more if it's not diesel because they have to install a way to fill it. Otherwise, it would just connect to the existing tank. They're located fairly close to my home.
The 59 blower is comparable to a 6008 blower as long as you are using 2.5 hose AND it is well plumbed. Otherwise you will be disappointed.
Can't you try one before you buy something?
