Bob Foster
- Joined
- Oct 8, 2006
- Messages
- 8,870
Interesting findings comparing a Chev cargo van vs a Sprinter Van
The sprinter is 10 inches narrower however the back door opening of a sprinter is larger Chev is 57 and a Sprinter is 61
Even with the narrower width overall of a Sprinter you could mount a reel and a truck mount beside each other facing out the rear doors. And on the Sprinter the doors wrap can completely around the outside to up against the side panels to be out of your way.
A Chev side door opening is 44 inches but the Sprinter larger at 51 inches. So that means you could also put a reel and TM beside each other and both would be fully exposed facing out the side door leaving the whole back end open to versatility for what ever you want.
The raised roof sprinter has tall walk in height both on the side doors and the back doors.
The working deck on the Chev and is 27" off the ground and the working height off the ground of the Sprinter deck is three inches higher than the Chev.
Max length on Chev 155" Sprinter 170"
Max payload Sprinter 4012 Chev 3992
http://www.thecarconnection.com/specifi ... dimensions
I know which one I would rather have.
