- Joined
- Oct 6, 2006
- Messages
- 117,272
Kevin if you own a op unit go attach a zip tie to a pad or bonnet and then run it on a floor. Tell me what happens
Brush or bonnet?The Sprayborg rotates at 80 rpm and oscillates at about 1700 cycles per minute. So a little less than half the speed of a 175. If you turn it upside down, you can still sit on it and rotate. Just a little slower.
what ever you are most comfortable with. The brush will probably help with your hemarhoids. Scratch that niche.Brush or bonnet?
Need cloth to actually do any cleaning. But scratching that itch feels good just no actual cleaning.what ever you are most comfortable with. The brush will probably help with your hemarhoids. Scratch that niche.
That's why I have cimex and eco-17 machinesI've watched a label/tag sit in one spot and jiggle away on rough glue downs., under resistance they jiggle far more than the spin
A very large vibrator.the Eco17 is a jiggler, right?
a brush has never been used on a full sized OP machine..
Mytee makes both a carpet brush and T&G brush for the ECO-17 now. I haven't heard from anyone that has used either yet though. I plan on ordering the T&G brush for mine soon.
I don't have enough posts to post a link but Google Mytee A133 and Mytee A135 brush.
I've had it since early October. I clean part time and only use it about once or twice a week so I don't have as much use with it as some full time cleaners do. This is my first OP machine but I really like it. I was using a 175 before and I definitely feel like it cleans better and quicker. I'm also much less fatigued afterwards when using the Mytee. Great on CGD as well. I don't have many complaints with it other than the fill tube always leaks when you lay the machine down to change a bonnet. I ended up tying a knot in the tube and don't use it anymore. I may change the jets out as well as they put down a ton of pre-spray even when I feather the trigger.
and?Had a very interesting talk with Jeff Hruby today about brushes and supposed 80 rpms.
