- Joined
- Oct 22, 2012
- Messages
- 28,154
- Name
- Ron Marriott
Just had a recall of Sabra brand hummus. Apparently, it is contaminated with listeria.I'm forwarding this to the Humus Anti Defamation League.
If we were on the show TrailerParkBoys...I'd be the tall guy with a glass of whisky all the time, and you'd be the Trashy treiler park security guardHe's trailer trash. He can't help himself.
Get off the swivel tool boat for just s minute and open your mind on a more simple Pivot stair toolA swivle on a stair tool AIN'T about the risers as you're about to find out.
That's where the 10" CRB shines.No manufacturer has taken the initiative to created a great stair tool as far as I know. Closest is the PMF Saigerized 2 jet swivel but it's far from perfect.
Bull noses are the tricky part. Most manufacturers just prefer to pretend they don't exist, as far as I can tell.
It doesn't need to spin around in stairs. It just needs to pivot side by side. Just cut the head off the tool, attach a stiff, cheap and stiffer vac hose to reconnect it, and you have a pivot.
That's all that's needed for a spiral staircase
PVFFFF!lol..
While you SPECULATE, I KNOW.
Obviously you've discovered something that we, the little people haven't seen yet on the swiveling stair tools we've usedRead what I said Matt.
It's not about flipping the head.
Don't worry Matt by the time they get done with the "perfect stair tool" we couldn't afford one any way.Obviously you've discovered something that we, the little people haven't seen yet on the swiveling stair tools we've used
So, I'll go back to my corner and patiently wait for you to show us the benefits you've found
But don't forget, if it's nothing but hot air that we see, I'll harass the heck out of u, lol
I give up
Use a Zipper.
If my concept works the 2" hose really WON'T be a problemYou need to make both 1.5 and 2 inch versions
The Swivel IS A MUST with my idea.....I will do my best to get this going.....The tube and angle of the tube is a big key in how it will work, the size of the head is also very important, the wider the head the more it will keep you centered in the staircase to allow you to get square into each corner without any crazy body manipulations.Swivel & non swivel too.
I do agree with you but I also have to say, Joe Bristor of all the things I miss from him is the LIL BETTER vac hose, that vac hose is without a doubt a great product, I have used FACTORY 2" hose and I can totally see WHY guys hate 2" vac hose. The little better hose he sells is so nice a flexable in all honesty there is no reason not to go with it, it comes off the wand and down to the ground due to its flexability, he really does have a great product in the LIL BETTER hose.Not that it won't work, many carpet cleaners prefer to use a 1.5 whip especially for residential cleaning. Portable guys also need to clean stairs as well and they normally use 1.5. Personally, I use 1.5 unless I am using the Zipper. Yes you get better drying times with 2 inch but imho, not enough to warrant the hassle of 2 inch hose.
When is the new swivel oiler going to be available?If I do a stairtool, it will have to go through PMF, it will have to be a sheet metal formed tool, They have this down, to make a stair tool with a machined head would just put it way to costly, due to the fact it is just a tool that doesn't get used offten it will have to be very affordable.
I do believe it NEEDS to swivel PMF is very close, but I think if PMF and I work together on this we can come up with a very awesome stair tool...and it WILL BE 2" I don't want to have to use a adapter, I want to just go from cleaning carpet to cleaning stairs without the trip BACK to the van cause I forgot the stupid 1.5 hose or adapter.
My idea, "IF" we can make it work will NOT be a problem using 2" hose
