rhino1
Bawb, have you ever heard of a SG mounted in a dodge that after it ran for a while the tranny fluid would run out of the vent of the transmission? This has happened a few times and I talked with a few tranny shops, finally found one that told me this particular transmission doesn't move fluid very well and in a PTO application would likely get hot and push fluid out the vent. Tech suggested fluid may move a bit better in neutral than park, so I started running in Neutral. Works pretty good, but still get a little fluid on really hot days. Have you heard of this before and is there a fix, besides a drip pan in the driveway?
