T
The Magician
Whats Steve Smiths vac-away products webb addy? Thanks
JB said:looking forward to meeting you Steve, and thanks for your guidance on my "problem" ori. :mrgreen:
SteveSmith said:Try comparing Dirt Assassin by using it at 2oz per gallon vs other liquids with a pH <10 at 4oz or more per gallon and I believe you will see that it is actually very economical as a prespray/TLC. 2oz per gallon will work great on average soiling and is what we recommend unless you encounter heavy soiling. On heavy soiling up the dilution to 4oz and go to 6oz on extreme soiling and deodorizing.
Other qualities of Dirt Assassin that add VALUE to it and are absent in lower cost products are:
1. It doubles as an excellent deodorizer when given 10 - 15 minutes dwell time.
2. It dries completely non-sticky. If you dry some of the pure product in a shallow dish you will see that, even at that high of a concentration, it dries to an encapsulating film that resembles saran wrap. Because of it's completely non sticky and encapsulating nature it can be used with HWE or low moisture systems without fear of re-soiling.
We will have Dirt Assassin on hand at MikeyFest for anyone to test side by side with any competitive product.
Thanks,
Steve
SteveSmith said:Hi Nate,
I would reapply it if it dries completely. It dries to an encapsulating film.
Here is a scenario for you... Let's say that you presprayed a room heavily with Dirt Assassin and then your truck broke down or you could not complete the job for some reason. Dirt Assassin would not cause even the slightest amount of resoiling if it was not extracted.
As far as beading with KleenShield... NONE. We do make any such claim because it does not contain flurochemicals. It contains a good amount of acid dye resistors to replace lost stain resistance in stain resist nylon. It will also give acid dye resistance to wool.
If you want both stain resistance and beading then you would need to use our RhinoShield. RhinoShield is a protector only, not a cleaner... KleenShield is a cleaner and an acid dye protector all in one step. Buy some, test the heck out of it... if it fails, simply call us and we will refund your money and you can keep the KleenShield. We always give a FULL MONEY back, no hassle guarantee on all of our products.
We try to make sure you can't lose. I was a carpet cleaner for over 20 years before becoming a manufacturer and I bought a lot of useless chems. I do not want our products to ever be classified that way... Our goal is to satisfy you with very high quality products and if you do not agree that a product performs as advertised or you are not satisifed for any reason we'll just refund your money.
Thanks,
Steve
Porkfritter, I met her at MF6 and she was very nice, very professional and good looking too.His daughter is a bit bossy though. I think Shirley was really her mom.
