Trip Moses
IMOL
Saw an interesting Facebook post today. Evidently it’s become standard for some cleaners not to attempt red stain correction? I still do, just curious if I’m being cavalier?
I'm promoting you from idiot to village idiot. Keep up the good work and you can become county buffoon.If I see it, I remove it. Unless they won’t pay me to.
How hard is it to squirt some red remover and let it sit while you clean?
If it needs heat, that's up to Mrs Smith. Even though color loss more than likely wont happen... Still better if she says go for it.
I don't come across red stains nearly as often as I did 25 years ago. My customers either wised up or I have better customers these days.
Yes, that does work Matt.I saw Courtney's confession on there while he was working through that house with Kevin. I think most people don't know the efficient way to do it.
They just spray some red treatment on it, put a cold wet rag (unfolded) on top and let the steamer or iron sit on it, risking a burn or color loss from getting too hot. Therefore causing a big risk and hating the process.
But if you spray the spot, get a big wet rag folded twice...lay it beside the treated area with the iron on top of it, (preheating the rag), for about 25seconds, then put the hot side of the rag on the treated area for just 10-15 seconds with the iron on top, then flip it again, you'll see it happen much faster and much less of a risk because the hot rag is doing the work, not the iron. And if you don't see any change in color of the red, just move on. It's permanent. No time wasted.
People stopped drinking the koolade.More polyester and triexta (crap as it is) is part of that. The other is that red drinks don’t seem to be as popular. Coffee, tea, wine, and urine seem to be more common. I see more hair dye than food dye.
Do you have a real high heat unit? I've never had any luck with oxidizers.It all depends on the type and severity and does the customer want to pay for the attempt. I have a lot of success just using oxidizers or reducers without having to use a steamer. Depending on the job, sometimes I charge extra, sometimes not.
Ya you might not see a lot of things HahahahaCharge enough and you'll almost never see synthetic red stains
I do but usually the oxidizer doesn't need heat. I will treat with 40 volume before I prespray. The alkaline prespray will boost the action of the peroxide. A lot of times it's gone before I rinse. For residual red stains, I use a 2 part peroxide/ammonia solution. It may take up to 4 hours to work. Spray and walk away. I call the next day to check if it's gone. Usually, it is.Do you have a real high heat unit? I've never had any luck with oxidizers.
Ya you might it see a lot of things Hahahaha
I will try Cobb's. Is it a 2 part?Cobbs dye stain remover is good stuff better then Red1 I have the power steamer from Interlink $60 and it takes a minute to heat up but it will knock out a lot of stains fast.
Exposing the chemical to the iron face??? Who cares? NERDYes, that does work Matt.
Only problem?
You’ve now exposed that chemical to the iron face..... I find that using a steamer works very well, it’s slower, but much safer....
