super glue trick
I was replacing the coils in my car today and the 2nd to last bolt head was stripped. It was all the way in the back and it was recessed. I super glued a cheap socket to the head and let it sit 5 minutes. It came off easy as pie. I've used it in the past and it works most times.
Gene
that is a cheap good method if it works well most of the time.
Bob Foster
Use superglue to weld on a tool to pull out a soft dent too.
excellent, Gene!
I too hope I remember that little tip
BTW, if you soak the socket in acetone, you'll get the cheap socket back for another day
Ron Lippold
just use a piece of paper that way you dont ruin the socket
Couldn't get a hand drill in there? I love my lil' "Grabbit" as seen on TV extractor set, used it on Mikeys hose reel on abolt head that snapped off, easy as pie.
Shorty
Shorty Glanville
Okay, one from a retired L.A.M.E.
For those small screws that keep unscrewing, paint over the head with nail polish.
This will stop the screw vibrating loose.
Ooroo,
:roll:
