Sep 9, 2007 #1 Steve in Omaha Member Joined Mar 28, 2007 Messages 1,598 Location omaha ne Name steve snail Is there a compelling reason NOT to have swivel hose end connectors on BOTH ends of the internal tm water lines?
Sep 9, 2007 #2 Jim Martin Supportive Member Joined Oct 7, 2006 Messages 10,878 Location Arizona Name Jim Martin when I had all my new ones made up I had the make them with swivels on both end.............the only way to go..... much easier to deal with........
Sep 9, 2007 #3 Shane T Member Joined Nov 7, 2006 Messages 1,663 Location Waukesha, WI Name Shane Tiegs Are you able to get them with SS connectors? I've seen rust and corrosion inside over the years. When that stuff breaks loose it can cause problems.
Sep 9, 2007 #4 Jim Martin Supportive Member Joined Oct 7, 2006 Messages 10,878 Location Arizona Name Jim Martin yes you can...it is a lot more spendy and sometimes hard to find a hose place that has the (at least here) SS ends but they are out there....... I had to go to about 5 different shops
Sep 9, 2007 #5 Steve in Omaha Member Joined Mar 28, 2007 Messages 1,598 Location omaha ne Name steve snail down on the ss. Thank you Jim! kinda what I always thought.
Sep 9, 2007 #6 Jim Martin Supportive Member Joined Oct 7, 2006 Messages 10,878 Location Arizona Name Jim Martin just be aware you will have to also change some fittings to accommodate the swivel on the hose there also are fittings that have the swivels instead of on the hose itself....
