swivel hose end connector
Steve in Omaha
Is there a compelling reason NOT to have swivel hose end connectors on BOTH ends of the internal tm water lines?
when I had all my new ones made up I had the make them with swivels on both end.............the only way to go.....
much easier to deal with........
Shane T
Shane Tiegs
Are you able to get them with SS connectors? I've seen rust and corrosion inside over the years. When that stuff breaks loose it can cause problems.
yes you can...it is a lot more spendy and sometimes hard to find a hose place that has the (at least here) SS ends but they are out there.......
I had to go to about 5 different shops
Steve in Omaha
down on the ss. Thank you Jim! kinda what I always thought.
just be aware you will have to also change some fittings to accommodate the swivel on the hose
there also are fittings that have the swivels instead of on the hose itself....
