Well there she is......................
This morning I decided that I was going to make a few extra changes so it took me longer than I had planed..
I moved the chemical pump and the shut off to a lot easier place to get to
(3rd picture red horizontal valve)
The 4Th picture is of the throttle control cable and assembly............there is no set place for this and the bracket was sent with no mounting ......this was the best I could find for it and it works great.....easy to get to and it is almost back in the same place.............
I fired it up and it ran like a top..........not a single hick-up or leak...........
If there is anything in particular anyone wants to see let me know..........
also if it is possible you may want to go to this type on chemical jug.
Gravity feed it the way to go...........the old system was so damn hard to prime and get going .....this thing was completely dry from the switch over
once I fired it and got it going it was nothing to prime and set it..........
http://www.beyondclean.biz/watertank.htm
