Going to replace the hose between the pump and the regulator in the AM
Mikey P said:Jim Martin sent me a new V specific regulator and all is good again'
phew :!: :!: :!: :!:
Thanks Jim!
See you at MF!!!
Mikey P said:I hear that if you clean your heat exchangers real well your tires last longer.
Thanks Jim!
See you at MF!!!
Walt said:Mikey P said:Jim Martin sent me a new V specific regulator and all is good again'
Thanks Jim!
See you at MF!!!
Where do you get one of these? My old v has the same problem.
That would be my guess. It's not getting the rpm's it needs to create higher CFM.or its the govenor
sam miller said:You feel loss at the wand with psi? no pop? If not maybe your pressure gauge is going bad!
My old 405 in low speed setting wont go over 5 hg,10 in high speed and in low the engine rpm goes up and down.
I think I need new spark plugs or a rebuilt carburator or its the govenor. My tech is gonna take it soon and look it over i'm not smart enough.
Jim Martin said:Walt said:[quote="Mikey P":97i32mpd]Jim Martin sent me a new V specific regulator and all is good again'
Thanks Jim!
See you at MF!!!
We check the regulator by crimping the bypass hose with a wand spraying.Lee Stockwell said:Depending on plumbing you may be able to prove this by severely restricting the bypass outlet, (which is usually routed back to the low pressure inlet side of the pump, either directly, into a waterbox, or into the fresh water tank.)
