- Joined
- Oct 7, 2006
- Messages
- 50,008
I'll just buy one of Duane's units.
Much better overall design.
hogjowl said:I am beautiful ... just ask Lisa.
I was talking about the TM.
Greenie said:wait a min?
All blowers already have a fill port and a breather port that I know of. Why would the pressure be any greater than any other blower if it was properly vented?
Or is there some blowers out there with PLUGs installed where breathers should be? :shock:
ps: Hogjowl
If you want a 150-170 gal waste tank, it's gonan take up some space, how about you just settle on a classic TNT with the 120, it's MUCH narrower.
John Olson" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">John,John Olson said:Les did you get the update from Gardner Denver about adding breather ports to the blower? Not sure how many you have put in the field but they had bad run of blowers that the front seals leak. The Breather port was supposed to help.
bonesheal said:What would be required to attach a freshwater tank to the C-4?
Disclaimer: I'm no mechanical genius (and I may be about to make that obvious). I was looking at a TNT and it looked like I would need to remove the freshwater box and route the hose inlet to the freshwater tank, a hose to draw from the freshwater tank to the pump, and a relief hose (back to the freshwater tank?). Is this correct? How do other people do this, or does everyone always use it with a water supply?
KevinD said:bonesheal said:What would be required to attach a freshwater tank to the C-4?
I am not familiar with the TNT but you should not have to remove anything.
A simple 12V transfer pump between the fresh water tank and the mix tank on the TNT is all you should need.
bonesheal said:KevinD said:bonesheal said:What would be required to attach a freshwater tank to the C-4?
Is it necessary to put a transfer pump in? I would expect the pump to draw water out of the freshwater tank without an auxiliary pump.
Johnny said:I think my pump has a 25 psi minimum feed pressure. I do an old building where the city pressure is low and I can get only about 400 psi atm without pump chatter.
Ron Werner said:I can take a pic of my set up if need be. I have the CanAm which is the predecessor of the C4. The tank below mine was supposed to be the fresh water tank but I put in a 200gal tank. I ran the feed line directly from the pump into the tank with a filter on the end and a second line into the tank for the bypass. Been working great for over 18mths.
