Temporary soaking pit
Ken692
Boston
Kenny
I'm in need of a temporary pool, something that I can adjust the size, I was thinking I could use pool noodles to create a tank, I just need something I can use in the garage to deep soak a rug. Any ideas, you guys always come up with some great solutions.
cleanking
Indianapolis, IN
Jordan King
Years of Experience
19
Role
Business Owner
Ken692
Boston
Kenny
Not cheap but looks like some good quality, the rug is huge at 15'
Do the liners run this large? Or do I need more than one?
cleanking
Indianapolis, IN
Jordan King
Years of Experience
19
Role
Business Owner
Considering you can use this liner for years I'd say $1/sq ft is pretty stinkin' cheap ha!
They come in a lot of sizes just do a search.
Reactions: Ken692
Hawaii
I've heard of guys using 2" vacuum hose instead of the PVC if you have it.... PVC would be easier if you didn't want to mess around with laying out the vac hose...
Reactions: Ken692
Shelbyville TN
I have built several with 3" PVC as it works as good as 4" and is a bit easier to assemble and cheaper. Keep some different lengths around to make different size pits as needed.
Orbitec in Birmingham , AL sells rug cleaning equipment including liners up to 18'. Very good quality. But if this is for a one use and discard situation, 4 mil; or 6 mil poly works fine. We can sell you a big roll and cut to the size you need. http://interlinksupply.com/index.php?search_val=poly+sheet
Shorty
Cairns
Shorty Glanville
If you go to the Amazon link &scroll down, you will see larger sizes.
15 x 15, even a 15 x 30
Get some long L shaped steel brackets, (or make them up from flat steel), drill some holes in them and screw to the pvc pipes to hold them in place.
:yoda:
Reactions: Ken692
Ken692
Boston
Kenny
there is a link here with a rolled up rug and a shopvac, did a great job removing most of the moisture.
And a good extraction. Most recommend dry laying flat.
Toys R Us has a fine selection too
Reactions: cleanking
J. Brightwell
Mass.
David Moynihan
I have a wash pit built with pvc pipe and pond liner. I had sleeves sewn on the liner so all I had to do was slide the pvc into the sleeves and connect with the elbow joints. Pretty easy set up and break down and requires very little storage space. The pond liner is fairly thick - can't remember the exact mil thickness - but is not 100% water tight. I just ordered this to replace what I have. There is also a heavy duty option. http://www.chemicalguys.com/Car_Wash_Mat_Water_Containment_Mat_p/acc_m1.htm
cleanking
Indianapolis, IN
Jordan King
Years of Experience
19
Role
Business Owner
We have a 45mil pond liner, that we aren't using as much anymore, it had no problem with leaks whatsoever. Very water tight.
Reactions: Ken692
T Monahan
Ann Arbor, MI
Tom Monahan
You can also fill the smaller diameter tubes with water to make quick soaking enclosures on the wash floor. (Robert Mann's idea is inexpensive)
We also sell the new version Rug Suckers offered by Rugged Industries.
http://centrum-force.com/rug-sucker.html
