Thank you Mikey's Board and Turbo Force!
Blue Monarch
Dirk Wingrove
Out with the old and in with the new! I won the Turbo Hybrid auction. Was in the market for one, so it was perfect timing. I've been using the original Turbo for about ten years and have loved it. Made me a ton of money.
I haven't had a chance to use it yet, but man, the build quality is WAY better than the original. Love it!
Reactions: BradD and BLewis
Congrats!
Man that worked out great for you Dirk, especially as much T&G as you do.
You're a testament to how good their products are, rockin that old school version! :winky:
Set aside five bucks from every tile job for your M10F funds
Blue Monarch
Dirk Wingrove
lol.....it'll need to be more than $5! This market doesn't have near as much tile. It's coming though.
Lucky!
Both.
But not at the same time.
I never use the Teflon ring although I suppose if I had 100000s of ceramic to clean I would take the four minutes to swap it out
curt johnson
Curt Johnson
Dirk, I have a question. The shaft on the older model looks much straighter than the shaft on the newer one, is this true???
Steve Lawrence
The plastic ring will dry floors better but you run the risk of getting a small stone or grit embedded in the ring which would scratch the tile causing a major problem. We prefer the brush ring for that reason.
BradD
Congratulations Dirk! Wow, what a blast from the past. It has been a while since I’ve seen the old Turbo. What a great picture. It is awesome that it has given you so many years of reliable service. Here’s to another 10+ years. Thank you for sharing your success.
