Did you check the flux capacitor?
If not, check these out. I have a briggs too and had the same problem. Start from the battery and work your way back to the engine. Its most likely the VR that is going out or a bad battery.
Bad battery
voltage regulator is going out
bad battery wires
stator wire got cut
the magneto coils went out
