Mytee will take care of the virtual squeaky wheels, that's for sure..
Larry about that.... How much are the replacement motors and pumps in 240v vs 120v versions? The current Bissell Big Green extractor is a 120v unit and I have a very large step down transformer to use it. Now that I have this device the voltage issue is not really a problem. If the 120v parts are cheaper (and given that the 120v market is so much bigger I'd expect them to be) then I'd rather stick with 120v equipment.Grant;
The Mytee 1005DX with the new Cat Pump is the extractor I would look at.
It can clean carpet or Grout/Tile with top efficiency.
Available in 240 VAC also.
Larry
BUMP......Larry about that.... How much are the replacement motors and pumps in 240v vs 120v versions? The current Bissell Big Green extractor is a 120v unit and I have a very large step down transformer to use it. Now that I have this device the voltage issue is not really a problem. If the 120v parts are cheaper (and given that the 120v market is so much bigger I'd expect them to be) then I'd rather stick with 120v equipment.
If there is parity (which seems unlikely) then I would be happy to buy a 240v unit when the time comes.
What is that unit worth Larry, and do you ship internationally?
Grant
A few Little annoying shortcomings but a good powerful unit none the less.
I have the Mytee DX 105. A few Little annoying shortcomings but a good powerful unit none the less.
who? your mytee or Crazy George?
I was joking when I posted the "truckmount booster" and to my suprise Melty has built a line around it.
Here is a fun experiment...
Everyone with a Melty that uses 2 cords and a circuit locator.
Plug one in the house, and plug the other in a generator..... Count to 10.... Then put out the fire...
I thought that motors are also affected by the 50 versus 60 Hertz, does the step down transformer take care of that?
I usually run 50 feet, occasionally 75 feet of 2" hose, very decent vacuum.
