GCCLee
I am also not thrilled about trying to keep that Stainless looking pretty after the honeymoon wears off.
Pimp my filter ?
TMDRY
You more than likely have the SS Dev that did not have rubber gasket in back I used silicone and it just won't hold up. I have been at this for a while now and you can not seal with goop,I know as I have tried it over the years, If you send me your filter I will fix it for free, and send it back, if you like just a offer then if you did use it it won't make the whiny noise anymore up to you. I have also got rid of the old stlye gaskets that did not seal very well up front with a much better quality gasket. My personal SS Dev the very first one leaks a little air and it dripped water out the front but not with new gaskets. I haven't really heard anyone complain except the JB followers all of the sudden the Dev is the biggest POS on the market and it has so many problems yet I haven't heard from but a few and I try to take care of them if I can.
Thanks guys for the nice posts I wish I could make it this year to MF but for some reason we have been fairly busy cleaning, my son is almost ready to take care of the cc company but not just yet needs a little more time getting used to TM start and set up, next year I more than likely come down to meet you all would be nice to get away.
I removed my lint basket in my Prochem tank because it was killing my air flow and replaced it with the Devastator Filter. Its a little over $200 but my dry times are amazing and my air flow is amazing through the whole job. It is unlike any filter on the market, it is one of those ground breaking tools that will be copied in the coming years.
The owner is a carpet cleaning business owner who has spent the last 4 years or so coming up with this filter. I do believe there is also a mini version that is being tested as well. I think one of these filters will be at MF, so check it out.. it is worth the extra dough over the other filters.
If you have a smaller TM, this would be perfect for you by allowing your machine to breathe easier and give you better suction. I was going to see about upgrading to a 5+ blower for my next machine, but see no reason to go that big since I am 150 ft and under 99% of the time.
Bottom line is that its a tool that will make you a better cleaner.. the thing is built like a tank.
http://www.devastatorfilter.com/Models-and-Prices.html
which prochem waste basket had you been using?? there are 3 I know of the factory aluminum one, a stainless after market unit that has small holes and a stainless aftermarket unit that has holes the same size as the factory aluminum basket. the only unit I have had trouble with is the aftermarket basket with small holes. the other 2 work fine as long as you keep them half way cleaned out. they should be good for a days worth of cleaning. I keep a puddy knife near the tank so I can give the sides a quick scrap and move the debris to one side if I am too lazy to clean it out at that moment. I have never seen the need to use an auxillary filter with a prochem machine.
