In one of our set ups we had a jabsco industrial water puppy pumping fresh water from the tank to machine and the impeller kept going, whether it was friction and heat or who knows but it died two weeks ago in the beginning of a huge day, I keep a back up impeller on the truck but it seem to be the impeller housing so I stopped at a bait and Marine shop and grapped a RULE Fresh Bait pump and some sturdy bilge pump hose anda couple step down connectors and clamps. $158 later(would have been less but I needed the step downs and clamps because I was doing it on the fly) I have an awesome pump that automatically turns on and off without high level switch or anything. It has been incredible how well this has worked, I am curious how long it will last.
If it lasts next go around when the other two start to fail I will definitely go this route, simple easy and I can not see how it can fail. 3 yr warranty
