The Future of Cleaning: No Chemicals Needed . . .
Ozone doesn't penetrate well and has never been very effective against urine in my experience.
Are expecting the amp'ed up ROS to do more than standard Ozone on the urine? I think you'll get good kill on the surface but I can't see it doing anything for the pad or subfloor.
We can get 6 log kill with our system but it has the same issues with urine. No penetration, no kill.
I guess you could put an open QC . . .
and flood the carpet to get the Hydroxyls down to the pad level .
Before using the spotting claw.
I will be only extracting a cat-lady room of 50 oz. plush
in the new few days as a test.
Too bad we don't have smellaphones.
So if I pumped the output of my ozone machine into the rinse water, or inducted it into the line, it would desmellify things?
I can see me changing the company name to "Steam Punk Cleaning."
Reactions: dgardner
Gases just don't have the penetration needed.
We will be generating the Hydroxyl ions in the injector and spraying the solution into the carpet.
Hydroxyl ions are stronger than Peroxide and Ozone in oxidizing ability,
yet safer to be around.
The same with our equipment. The conversion after the solution passes through the cold plasma arc creates a product capable of far great efficacy that peroxide alone.
