- Joined
- Oct 6, 2006
- Messages
- 117,187
BUILT FOR SPEED!!
The industry’s most advanced tile cleaning tool, the SX-15, just got slimmer. The new Gekko SX-15 attaches an SX-15 head to a Gekko wand to create an even thinner profile for this tile cleaning monster. The Gekko SX-15 was created after numerous requests for a wand-style set up for the SX-15.
The AR51S includes all components necessary to attach the SX-15 head to a Gekko wand #AR51A.
FAST
http://mikeysboard.com/the-hugely-popular-sx-15-is-now-even-more-versatile/
FAST
- Industry-leading 15″ cleaning path allows you to clean 25% faster than 12″ models
- Aerodynamically-engineered radial vacuum line creates a laminar-flow vortex in the cleaning head that allows the SX-15 to remove water twice as fast as competitive models
- Tool-less design makes changing the boots a breeze! EZ-LOC™ boot uses no screws or pop rivets, simply release three locking levers to change your boot on the fly!
- Toe-adjustable vacuum relief lets you adjust the suction strength on the fly
- Low profile allows the unit to fit under toe kicks
- Easy access inline filter makes cleaning the filter a snap
- Quality components will handle operating pressures from 700 to 2,600 PSI so you can blast away oily deposits
- Stainless steel handle and high-tech polymer casing will take a beating and ask for more
- Lightweight construction makes it feel like the machine is floating along the floor
- Tool length is comfortable for users of all heights
