The ol' Vortex is showing it's age
The guys checked the oil yesterday and it was 3 quarts low. (11 capacity)
(yes I know, should have been checked sooner, but shes never been a oil burner till now) My bad.
Due to my foot and training the new guy it has not seen much use since it's last oil change three months ago.
No leaks but we do get a black wad of soot blow out the exhaust HX on the first job every AM.
She's got a bit over 500k on her combined.
Jim Martin recommended trying a diesel Oil additive to help lube up the seal/rings around the pistons.
Any other thoughts other than trading her in a a new Dwell Pro?
Dave Rampage
check the end of the exhaust, rub your finger on the inside. If it's wet then your rings are letting oil by if it's not wet you don't have that problem. Puffs of black smoke may just mean it's running rich. Don't do this in the morning after you start it up. There will be condensation.
Erik
Michigan
Erik
I would read your owner manual, you are way overdue. Should be done every 40,000 miles.
Hawaii
What about the whole Cali diesel thing? I thought you needed to replace the older machine to become EPA compliant? Isn't that why most were selling there older Vortex?
Boca Raton
That engine should go much longer. Add the Lucas and get the valves adjusted. Dave is dead on, you can tell a lot by the inside of an exhaust.
Gene
Doug Cox
Delavan, WI
Doug Cox
Valve seals? I was losing 1.25 quarts of oil per 100 hrs. Changed the seals and was back to about .3 quart oil loss.
BLewis
Lexington
Billy Lewis
Mikey, I finally got around to by passing my 24 pin connector yesterday. It quit mid job on my son the other day and all the wiggling in the world and I couldn't get her to power up. So I knew it was time for the surgery.
I think your V (like mind) suffers from not enough TLC. I had thought about selling her but where could you find a beast that can suck like her for $25k ?
I replaced that idiotic thing years ago.
By doing that and putting the exhuast diverter solenoid in a sealed box I got rid of a lot of headaches.
adamh
Nampa Idaho
Adam Hale
Maybe you will get lucky and it will catch on fire. Your insured right?
I tell my guy " if this thing catches on fire, don't put it out. Let it burn to the ground." '-)
Zee
SoCal jungle
Am I the only one around here, who is scared poopless looking out the front door of a house we are working on and see smoke billowing? Knowing the fact that the freaking diesel burner flow switch of the El D, is constantly getting stuck on the on position...causing the flame to burn while water does NOT travel through the system.
I guess lighting up a POS Duaneomount twice, with the propane burner doesn't help this psyche...
Add me to the fule bomb terrified list.
Found my Multi Sprayer filled with Cobbs solvent sealer resting against the little giant once
David got an earful.
I was on my way home from a job in Greenbow (about an hour south) on I-65 one day and smoke started coming from the engine compartment. I thought is was steam. I stop, open up the hood and it's not steam. Fire in there and it's growing fast. At first I panic ... and then I think ... insurance ... new van ... not so bad. By the time I get my wands and tools off loaded I can't see the van anymore. Smoke billowing everywhere. About this time I hear a loud hiss ... and I just about load my pants thinking it's the propane tank popping off. It's not, it's a highway department dude with a large fire extinguisher. At first I want to shout ... NO! LET IT BURN! I didn't. I politer in public than I am to you fools.
He was too late though. It was a total loss.
A week later and I was in a new van with another TCS in it.
And no, Satan, the fire was not propane related.
Noble Carpet Cleaners
never to late to run Marvel in your fuel. Best price is Walmart. Running a crankcase additive with that many hours on the engine is risky. Why, because there are deposits that if kicked loose could block small oil delivery orifaces. The safest/best time for the oil additive was way back on the odometer. I could go on and on about what a solvent based fuel additive will do for you, especially in a diesel. Marvel is the best kept secret.
