TimP said:
That's what I get for not checking to make sure....they have lists of all kinds of points so I was just guessing.
What is the cloud point of point blue if you know right off and say compared to heat wave from
prochem which is supposed to have a high cloud point???
You would think they would put information on packages that would pertain to what a cleaner needs to know about the product.
Tim,
You bring up the most important point. That being, what are the real world consequences of the cloud point issue. Generalizing, the cloud point of a surfactant is of actual greatest importance when cleaning with a portable machine, versus a truck mount. I'll explain.
First. actual emulsification is occurring during the dwell time the cleaning solution is on the substrate being cleaned, the fiber. Regardless of the temperature of the cleaning agent in the TM, or in the solution lines, the cleaning solution quickly loses heat the moment it hits the fiber. Within 3/4 of a second, the solution temperature on the fiber is well below 140 degrees f. Almost no cleaning agents we use have a cloud point below this 140 degrees. In fact most average around 140-160 degrees. Any settling out that might possibly occur is in the highly agitated state of the pump system or in the solution lines, which is also quite physically agitated. In fact, the solution stays very well mixed with surfactant, even though we are above the cloud point. It should be understood that the changes that occur above the cloud point are not irreversible. As soon as the solution drops below the cloud point, as long as the solution is well dispersed with surfactant, emulsification is free to take place.
In a portable machine, you have a static solution tank, where the mixed chemicals would have potential for the cloud point to become an issue. If the solution tank's mixed chemical is above the cloud point of the mixed surfactants, the settling out that might occur could lead to a problematic distribution of the surfactants in the solution tank. Here, you would definitely want a chemical
compound that is specified for the potential elevated temperatures.
So called "high heat" products are usually those with complex surfactant blends that have surfactants with various cloud point, each working at their separate peaks as a solution cools on the fiber.
There are essentially two points of high focus, when dealing with cleaning temperatures. First, is the temperature at which oils and greases melt. Second is the peak temperature at which a surfactant emulsifies (right below the cloud point). However, what cannot be said in these statements is the relationship of the effectiveness of a particular surfactant. Just because two competing or different surfactants may have an equal cloud point, it does not follow they have equal or similar emulsification reactivity or HLB values.
Why don't products list cloud point? Because it is not as much of an issue as simply having a manufacture use surfactants with a cloud point of greater than 140, which they do anyway. And if you see your portable solution go cloudy when you heat it to YOUR desired temperature, then you may want to consider asking, "what IS the temp range of this product?" for portable use.
It is my opinion that the use of "high heat", when describing a product is more having to do with the ability of the product's other components in the presence of heat, rather than the just the cloud point(s) of the surfactant(s). But I am sure that enterprising marketing will indeed use the moniker if the product's surfactant does have a rather high cloud point, in which case the surfactant should only be used in elevated temp settings to gain all the advantage of the product.
