Mikey P said:
[quote="Loren Egland":c7l41617][quote="Mikey P":c7l41617]man, look at that electrolysis going on on your water box.
I had that unit for a few months.
I wouldn't wish that thing on Rob Allen.
Now I know what you think of me!
My guess is you couldn't stand the HEAT! :wink:
For those who don't know, I bought Mikey's Powermatic, electrolysis in the 7 year old water box included at no extra charge.
[/quote:c7l41617]
too funny.
I don't get you guys who live and breath those damn things.
meAt talks about those friggen submarines kinder than he talks about his wife.
I don't get it, 8 miles of hose and wire, stanky heat, barnacles in the water box, needs a damn generator to work, fickle as can be pressure regulator system, small waste tank....good lord, so many better options out there.
Beauty really is in the eye of the true blew crew.[/quote:c7l41617]
Maybe it has been too long since I enlightened Mikey's Board about the Powermatic's features that other machines don't have. Time savers and back up systems to keep you cleaning. I know I will forget many of them, but I will try my best to remember why I bought that old boat anchor from you.
Cleaning performance number one. The PM can keep up better than other truckmounts with higher heat combined with higher flow.
Big beautiful impressive looking machine. Just ask my customers, and my competitors. Helps with the dog and pony show to get more jobs at higher prices.
2.5 inch vacuum system that is not restricted to over worked to build heat like complicated heat exchanger units. Once a carpet has been flushed clean, you are only extracting clean water.
Fuel oil burner. Only fires when using water flow. Almost instant heat. Higher temperature solution cleans better (with less chems) and dries faster. Less explosive than propane or gasoline. More btu's in Kerosene. (can run diesel but that is not clean burning like Kero) Easy to fill burner fuel. No outside the van tanks needed. No waiting for propane man to fill for you. Less complicated than heat exchange technology.
Auxillary generator for running power wands, lights, fans, compressors, steam irons, etc. If generator fails, just plug into electricity to keep the burner firing. This is a back up system to keep you cleaning.
Two pressure regulators makes it possible to have a quick 3-way valve for high, medium (carpet) and low pressure. Save time and acts as a back up system should one pressure regulator fails, just dial in the other and keep cleaning. Also holds pressure without the large drop seen in other machines when the wand valve is keyed.
Pump clutch that stops pump when waste tank is full rather than shutting down the engine and losing suction. Can run machine with pump off for water damage extraction. If you lay down wand and and don't key the valve, the pump won't overheat but will let a little water come into your pump to cool it down so it doesn't fail.
3/8 inch solution hose for better flow and pressure at the wand. Holds heat pressure better without the large drop, maintains heat better, flows more solution, and last longer than 1/4 inch. Make high pressure steam cleaning of hard surfaces doable with such flow and heat.
Kohler air cooled engine is reliable, simple, easy and reasonable to replace. Less gas consumption per hour. No water pump, antifreeze, hoses, radiator to go bad. Uses water cooling with a simple copper tubing through the fresh water tank. Keeps motor running cool and increases life. Engine shut off if lose oil pressure, preventing expensive repairs Plenty of Kohler shops around.
105 gallon usable waste tank, so the tank must be about 140 gallons in size. How many truck mounts come with larger recovery tanks? Did you know that the waste tank can be completely drained so you don’t leave waste water at the bottom to raise such a stink? Large lid makes it easy to rinse out.
High quality metals used through out. No rusted frame that can weaken and look unsightly. Stays looking like new. All Aluminum, Stainless Steel, Brass, Copper right down to the screws.
The PM can be had with a conveyor system to roll the machine right out of the van for easy maintenance.
8 gallon solution fill tank. Just turn the valve to ‘solution fill’ and you soap tank will fill with hot water. Combined with large lid, makes it easy to use powders, so more economical. Save much time mixing chemicals. Time is money. Also has ‘warm up ‘ mode.
Proven track record. (even if an occasional lemon shows up, as it does with all machines) Thousands of Powermatics sold over the last 30 plus years? How many other models can even come close? They are soon obsolete. No need to keep looking for the latest and greatest only to find out differently, that they don’t work as well as claimed or clean as well as the Powermatic. Bigger blower (requiring bigger more expensive gas hogging motors) should give more suction, but due to less heat and flow, still leave much to be desired. Average job is only 100 feet of hose!
As a slide in, it doesn’t wear out the van prematurely. Can be moved to another truck if your truck is down for a long time.
I suppose every machine has a down side for someone, even if it is imaginary. But for what a truck mount is supposed to do for your business, you could find a whole lot less but spend a whole lot more. Comparing the features/benefits of the Steam Way Powermatic Legacy 2100, there is simply no machine like it. A Lexus compared to a common Chevy, yet lower priced than machines that do much less, have much less, are much less.
There are other machines that can clean as well, but they are still no match for the Powermatic.
Loren
P.S. Maybe I will buy a lunch pail.
