Auction The Saiger's Sauce Fall variety pack!
Village Idiot
Auction includes:
  • One Case of our new Saiger's OdorOxy peroxide based stain and odor eliminator with special Saiger's Cide Mango Burst Scentsation odor eliminator $112.10 retail value
  • One Case of the original! Our Saiger's Sauce 1 Prespray that started it all $152.58 retail value
  • 2 Gallons Eloquence for Upholstery, Fine Fabrics and Wool prespray cleaner $55.12 retail value
Odor Elimination with the Power of Peroxide and a True Odor Destroyer!​
ODOR OXY is a unique high powered Peroxide formula with a true Odor Destroyer! Not a masking agent, but a product meant to go after the urine and odor causing organic stains! With the power of Peroxide and our unique Odor Destroyer. Designed for those cleaners who do not have the time for enzyme activation, and need quick fast results! Odor & Stain elimination oxidizers that will remove organic stains including pet urine, blood, coffee, vomit, and more. A unique formula to eliminate unpleasant stains and odors in carpet, upholstery and other fabrics.
Avoid using on Wool and Silk materials, and be cautious with natural fibers.
Saiger’s Sauce 1
The Power of the Blue!
“Bring on the Blue Bullet!”
Enviro Safe – Non Toxic
From 4 generations of Saiger family cleaners, we bring you Saiger Sauce 1”. The highest quality, very economical, multi use prespray you can buy. A unique product created by 50 plus years of cleaning experience and passion, astute observation and testing in real world cleaning situations. A “one product” to help with most of your professional cleaning needs on carpet, tile and grout, synthetic rugs and garage floors, stone patios etc..
Gentle enough to be your everyday pre spray or your Blue Bullet on greasy commercial work.
ELOQUENCE
Eloquence is a very unique Upholstery, Fine Fabrics & Wool Pre-Spray Cleaner, which has been field tested by the Saiger Family for quality assured performance. Eloquence field testing was performed in many areas of the U.S. as to ensure maximum safe cleaning performance regardless of conditions.
UN-EQUALED COMBINATION OF PROPRIETARY SURFACTANTS Our specific blend of wetting agents and emulsifiers are designed to remove tough oils and soils commonly found in upholstery fibers. Eloquence was designed for improved cleaning performance specifically for those difficult fine fabric/wool cleaning challenges. Eloquence has an un-equaled ability to cut through body oils, odors and every day household wear and tear of your fine fabrics and wool carpets/rugs. POWERFUL CLEANING ABILITY FOR THE MOST DELICATE FIBERS Saiger’s “Eloquence” can also be used on carpets and rugs where a lower pH is needed. You will see incredible cleaning & brightening properties not typical of products in this pH range. Our proprietary blend is a non-foaming formulation, making it easier to use.
$319.80 retail value with Free shipping to the lower 48
Starting bid $140
Minimum bid increment $2
Auction ends Wednesday 11/10/21 at 9PM EST/ 6PM PST
Village Idiot
If he doesn’t pony up put me in for $230
Kevin is an og member....I'm sure he just got busy/forgot
I'll try and hit him up on fb tomorrow
but after 48 hours I usually go to the next bidder
