The Shark UltraLite Rocket....
Noble Carpet Cleaners
had been catching my eye for the purpose of vacuuming upholstery. Appeared worthless for floors. Yep, turned out worthless for floors but remarkable for upholstery IMO. Ditch the long upright tube and attach the brush bar directly on the vac body. Hold on to a wheel with one hand and you can maneuver this thing over and edge and then back to flatter surfaces. 3 couches down and proceeding with caution on fabrics. The wide pet/upholstery tool is marginally useful. Holy sh.. you can cover some ground quickly.
Pros: -very fast at removing hair over wide areas.
-fairly good build quality, probably best you don't throw it around.
-can dump perhaps into a white bucket in front of customer to show and tell.
-hangs on a clip out the way.
-1st foam filter in the air path (and the others) are easily rinsed out with water.
Cons: -fills quickly in a small canister.
-1st foam filter in the air path needs cleaning fairly soon, like a Bissell Clearview.
-Doesn't come with a chimp to operate it.
-I put some money in the pocket of the dipsh.. with the huge eyebrows on T.V.
