Completed The ULTIMATE Nasty Challenging carpet cleaning package! Release of the Beast!
Village Idiot
Auction includes:
  • One Case 4 x 6.5 pound tubs of Code Red.
    One 4 x 1 gallon case of Harvard Chemical liquid soy G-Force Booster.
  • Free shipping to lower 48
Saiger's Sauce Code Red combines Oxy and Enzyme to the already awesome Saiger's Sauce 1. This unscented formula allows for the addition of deodorizers such as the new Saiger's Cide Lime Citron odor destroyer.
Directions and Suggested use
Be sure to mix with warm to hot and preferably “soft” water. Don't store more than you need on
your (hot) truck.
Pump up or Electric Sprayer
1 scoop (2ounces) to 1.5 scoops (3 ounces) of Saiger’s Sauce 1 per gallon of warm to hot water. Severely
soiled carpets may require up to 3-4 ounces per gallon. Test first so you don't waste this valuable
solution.
Hydro Force Type Injection Sprayer
Dilute 8 –9 scoops Saiger’s Code Red (16-18 ounces) per 5 quart container with warm to hot water, and meter
at 8:1 setting. If not using a metering tip, it is typically at 4:1 setting: THEN dilute only 4-5 scoops which is 8-10 ounces of Saiger’s Code Red.
Harvard Chemical G-Force Booster is a Soy Based Booster. Add a few ounces to your pre-spray to help cut through nasty grease and grime.
Retail Value: $316.77
Starting bid $200
Minimum bid increment $2
Auction ends Wednesday September 13th at 9PM EST/6PM PST
