The Wand Window...
TConway
Thomas Conway
How do you keep yours from cracking?
Marty,
I will send you some NEW windows, They should fit, you will need to put the slightest amount of silicone to the recessed area and put the new window in, I know it will work as I have done it on mine.
The new windows/heads have NO screws, I asked PMF to make it a press fit and they hit a home run, but they will work on the head you have too, and you can get rid of the 4 screws
Reactions: Steve Lawrence
Marty,
Don’t waste your time. Marty can’t see through the cataracts anyway.
I love the wand....
I love the window....(except when I see in the window what I might have been missing in the past :shifty: )
Reactions: Nomad74
back to the future of sight tubes .......
in the olden dayz, I discovered if you used foamy emulsifier and pre-sprays, carpet nectar that started up the tube dirty black became a nice light color foamy swill in no time ...musta been reeley clean huh...
Mow-rons
What do they call someone who speaks with authority yet has zero experience?
Mow-rons
:lol:
I had a sight tube when you were mosh pit'in with the other punkrock, pack following weirdos
Mullets, before mullets wuz cool :cool:
The issues were reliability related and failure.
Fixing was a problem and rivets through plexi glass for the win!
Sorry Larry the tube shows the entirely different picture than the window, I've had both and guess what you haven't..
Clear pipes have been around since the early 1970's. I had several Steamex box extractors with 5' long acrylic wand tubes. Later, 1976, several Vibra Vac power heads with clear tubes similar to what the Zipper uses.
Reactions: vibra-vacster
