bob vawter
Grassy Knoller
AND IN THIS CORNER
Naww i'm jus messin' wit Les...........Mr. 007 said:no takers huh.... pretty tough machines to beat!
Naww i'm jus messin' wit Les...........[/quote:2ldersda]bob vawter said:[quote="Mr. 007":2ldersda]no takers huh.... pretty tough machines to beat!
danielc said:If it is hx, how hot does it run?
meAt said:danielc said:If it is hx, how hot does it run?
I've seen Bob's work.
I bust the Ole Boys chops for fun, but his re-builds really are top tier
thanks Larr...i forgot to mention that my pimpOgenie uses a BUTLER HX'er...can't GET better than this...............meAt said:danielc said:If it is hx, how hot does it run?
liquid heat transfer, Dan.
It uses the van radiator coolant to run thru a HX'r .
It's one of the more (most) bullet proof reliable type of HX'r
as far as heat, 200 give or take in summer, 'bout a buck-eighty in winter..depending
bob vawter said:cool thanks Tim...the larger problem is fabricating an additional belt system on the front of the motor...
this involves an extra pully mounted to the harmonic balancer wit a tensioner....it's not exactly rocket science......but DOES involve a lot of time!
'maybe i forgot to mention...The Steam Genie is aThat sounds ideal for residential work.
bob vawter said:'maybe i forgot to mention...The Steam Genie is a
Dual Wand machine!
now what's that suppose to mean?now you just fell off the work bench........
bob vawter said:also...what kinna ports shouda been used on that tank.......
I'll hold Shawn F's ass on a fire for that!!!!!
TimP said:bob vawter said:also...what kinna ports shouda been used on that tank.......
Those plastic 90's are very restrictive, I don't even think they are a full 2" opening. A smooth flowing curve is better than an abrupt "L" shaped pattern. I'd like to change mine out on my CDS eventually.....but I'm a BDCC and have been doing without with no problems.
do they MAKE a male and a female with the smooth flowing curve?A smooth flowing curve
