The Xipp has arrived..
Other than a damn card table I am now the best equipped cleaner in the Carson Valley.
Eric's packaging job, and every last detail of the Zipper is so above and beyond professional.
It's a shame to actually use it..
Srv8h6Nr1TD2uBeAEuBPj_eccp9YF6NA_5N9nH9b7p7D9BbiY9VsKbTKL0DsoDm9CA_fgOgRnCNiHO2nkPZ=w513-h911-no.jpg
FMzxeGFqlV4BOfLZYHU1eBix3kj1dcNS649tvlDxUDklgFiVYG__9CM--qkXUU5hn0xEgfiBP2bEKcJBsm=w1620-h911-no.jpg
f-Xxivrv2NAjovCFC_FgSHI0DRCwfAN5F2-ohUUReubyrkEJC36E_FTH8mgiHVfAhjE9ebNNvo3p-DPjlWE=w513-h911-no.jpg
TA5kkCoh5bm5JRahHlOPN2aCQkgAFBK8BLlCqYlLGqX6-t5hzdJAKKYlZUBHmoXnxDiGhA4yqKCc8j1Wfs=w1620-h911-no.jpg
g5cG924xw-g_BcHrpvYPH0GmXpm1COkSuZRyTPmxC3-8XAZbjtO-TI_LA-KvsC3-DprGYzkOeU8ZeI4X-i_=w513-h911-no.jpg
89pe1T8m1raBV-rxlQE1xic6FZepxEQh0GptvA63OyJK_D5FPtFRor8qN0KkyXyaC5WiDcpNXWZ5-Yw2hy-=w513-h911-no.jpg
T Monahan
Ann Arbor, MI
Tom Monahan
Reactions: Pioneer Floorcare
Kellie Hiler
Georgia
Kellie Hiler
yes, according to Erik its the first 1 with the dog leg lurch handle...Starting with 7.5 flow..
I wish I had that handle, I am tall, but probably not as tall as you lol...mine is the 13 with 7.5 flow also. It does an outstanding job.
ronbeatty
Altoona,PA
Ron Beatty
Let me know how the new handle works, I will be ready for another Zipper in the spring. Two Zippers running off the Aerotech with the diesel heater will be really fast:)
Reactions: tmdry
Nampa, ID
Todd
You'll have to let use know how it does with the 370. I'm wondering if it has enough vacuum to get the results that most guys are reporting with the zipper and bigger machines.
Kellie Hiler
Georgia
Kellie Hiler
The roach clip is for cleaning the slot glide and the pin is for cleaning the hole glide.....and if yer wondering, the dowel is for changing the glides...lol.
@Mikey P is that handle not for people 5'10"? That's how tall I am and I had wondered if it would make it easier for getting under furniture on the low...
Total_Rookie
Beaumont, CA
Joseph Torrez
The vac will be no problem, But in all reality lower flow 6 Flow would be ideal [ 1 - 1.5 - 1 -1.5 - 1] Constant trigger at 375 ish.
Erik
Michigan
Erik
Reactions: Kellie Hiler
