The Xipp has arrived..
rjwood
Faux Fosythe
long gone
Me
Yes, I noticed that right away. I would personally prefer a larger, more robust handle that is situated higher and allow the the tool to lean against my upper arm for balance. Do you know what I mean?
Reactions: Mark Saiger
Noble Carpet Cleaners
That thing is a beast for sure. At 13" or 26 of glide "on the carpet" my money is on the 370 powering it no problem. Heat?, well who knows. How do you guys run these things? Full trigger w/no dry passes or back to dry. I full trigger my Westpak with a total of .06 at 400psi for about 20-25 sq/ft of carpet and then back to ring it out again. Stays about 195-210 at the machine. Still don't miss the heat of my propane. If I was still doing restaurant tile I might say different. But my 370 has cleaned about 3k sq/ft of residential so far at 1,000-1,100 psi (Turbo) and I still, don't miss the heat.
Grand Rapids, MN
My YouTube playlist on some operation of the Zipper...
https://www.youtube.com/playlist?list=PLg45027waKT80EdzcqzTZi518t2SZFi6D
One of the videos from there....
Reactions: Kellie Hiler
Ron K
Comparing Apples to Oranges 12 flow 50 flow how do you know? Do you fill a 5gallon bucket and measure not just go by what the #'s say on the spray jet. How many gallons per minute. Ralph Bloss told me 1.5 gallons per minute was the sweet spot for a Mastermatic. He and Henry knew each and every machines capabilities. Everyone seems to tweet (def Fiddle/Fu*&) with their machines.
Covert
Marcus
Use as much water flow as your machine will dry with ...more water flow more cleaning..
I never clean under 12-14 flow....
5-10 flow=1/2 - 1 gallon per min
10-15 flow=1-2 gallon per minute
Kellie Hiler
Georgia
Kellie Hiler
It's a running joke...Erik doesn't like to see dirty wheels or glides sitting on concrete. He gives everyone shit for it! Lol!
rwcarpet
Youngstown, Ohio
Robert Hodge
Other than a damn card table I am now the best equipped cleaner in the Carson Valley.
Eric's packaging job, and every last detail of the Zipper is so above and beyond professional.
It's a shame to actually use it..
Nice thing is.......glides are double sided, will last twice as long. As for mine.......it ain't as pretty, but it does a hell of a job!
