Thermal wave ii vortec no pressure!
Sutorbilt/Roots/Tuthill equivalencies:
5m = 56 = 5006
5L = 59 = 5009
4m = 45 = 4005
4L = 47 = 4007
The shaft configuration is identical between each mfg 1st column and 2nd column unit
However the longer lobed blowers have larger plumbing.
Austin Willoughby
Lee dude your full of knowledge I love it! Keep it coming I love understanding how and why things work!
5m = 56 = 5006
5L = 59 = 5009
4m = 45 = 4005
4L = 47 = 4007
For some reason I always thought a 4m had less power than a 45. After looking at the specs I realize that 2 of my trucks have 45 blowers. I think I was thinking that max rpm was 2600 instead of 3600.
Hack Attack
Dan
I thought cds was 47? Not that I know much about them, other than the local distributer refuse to bring them in 😕
The COMPONENT manufacturers are pretty transparent and accurate in their numbering nomenclature and description.
HOWEVER:
The truckmount MANUFACTURERS can and do use disguising terminology and misleading model descriptions that are, to put it bluntly, weaselly attempts to mislead.
Bane Clene would remove component ID plates and grind off the rivets before a bit of Krylon artwork.
Other manufacturers use equally misleading model numbers to imply bigger vacuum and performance specifications.
Austin Willoughby
What happened to your prochem performer? Btw I was kidding about tearing it down.
Well it needed quite a bit of TLC but ran and worked fine so long story short I thought well hell I'll tear it down and redo the whole damn thing. I resealed and painted motor, rebearing and powder coated blower. Cleaned up and painted other components, got to the frame which was rusted out on bottom and said yep now it's become to much for me to deal with lol. I just got tired of working on it really. When did you say anything about tearing it down? I must've missed that
I think that was aimed at his dad, lol
I have 3 machines on the bench, plus a trailer full of transplant parts. Will keep me busy this winter playing with them.
Austin Willoughby
Well if your interested in parts let me know bc I have all the parts off my old one except waste tank and water box
Austin Willoughby
How much psi are the stainless steel and copper heat exchangers rated for?
Austin Willoughby
SS usually more than 1000, depending on fittings.
Copper, like the Graham helicoil, 700 to be safe.
Garage- built usually less despite any claims.
That's hard to believe simple bc my thermwave 2 has copper engine coolant get echanger but is manual says it can produce 1200 psi?
Latest Auctions
