Thermoplastic Hose
Received some interesting new TM solution hose today.
Flexible 1/4" ID, lightweight, Blue, and 250 Degree Temp rating.
K
Ken Clean
Thank you for sharing that with us. Have you had a chance to try it?
No, just got it today.
Expect it to be similar in price to the Parflex.
I like the strain reliefs,.
T
Total_Rookie
@Larry Cobb answer @Desk Jockey ! I agree thermal plastic is the best and safest. I'm sure you will keep us updated. My last Parker just now started the pin hole leaks. I had to buy some hydro force steel braided in a pinch.. good hose but not Parker.
It did not come from Joe B.
It is the 1st fiber-braided hose I've seen rated for 250 degrees F.
It has a new inner tube.
Pricing has not been set,
but I expect it to be in the high $80's for 50 ft.
Another characteristic I noticed when comparing to wire-braid hose . . .
is more flexibility when under pressure.
The cover is polyurethane, which is several times more durable than the rubber on wire-braid hose.
P.S. Bristors thermoplastic hose is only rated to 1275 PSI.
Reactions: Mike Pailliotet
greencc
gary
does it come in 3/8 inch?
the hose doesnt need strain relief if you use the right connetors. a 45 degree angle at the machine and wand makes the solution hose not fighting gravity and easier to clear furniture in houses and condos.
I need some hose for the latest build Larry will pick it up next week.
Lyman
Lyman
The problem with thermoplastics and butlers is the small diameter center real. After two weeks you have a 150 foot slinky. Last one I had coiled itself under the van and burnt a hole mid way thru a job. Good thing I carry extra everything in the van.
I hate dragging around three or four loops that keep banging into the wall and furniture. :errf:
The nice part is you get the pinhole leaks before the hose bursts.
Reactions: Total_Rookie
Loren Egland
Loren Egland
I have used 3/8 inch wire braided solution hose since 1978. No coil
problem. Flexible.
Larry, how many psi is this new hose rated at?
3000 PSI working pressure.
But the main advantage is the higher 250 degree F temp rating,
increased flexibility ,
and lower heat loss (compared to wire braid) .
Bob Savage
Bob Savage
What colors does it come in?
Running dual wands I need my 2 sets of incoming hoses (2 vac hoses, 2 high-pressure lines) to be different colors so we can tell them apart inside where we are cleaning.
I don't like steel braid because of the high heat we sometimes clean with (over 225º). Steel braid will burn your legs and arms/hands when working with it, fabric braid won't burn you.
Initial 50 ft. & 100 ft. lengths of polyurethane cover Blue hose will be available in 4 to 5 days.
Introductory pricing is $89.95 for 50 ft. with strain reliefs & crimps.
Introductory pricing is $169.95 for 100 ft. with strain reliefs & crimps.
These prices are less than Parflex in the same sizes.
http://www.cobbcarpet.com/zen/index...ch_in_description=1&keyword=TX50BT+or+TX100BT
We also have yellow Parflex if you need a 2nd color.
Noble Carpet Cleaners
I drug parflex around for 2 years. Found I had to coil it up in large diameter loops (like 3ft plus) so it didn't lay like a slinky. Slinky loops were a non starter, for me that is. Tried cranking it on my reel a couple times, big mistake for laying it out on the job. The weight difference from steel braid was awful nice but securing 3 coils with bungee wasn't as easy and tidy then cranking steel braid on a reel. I have a 25ft section that has lasted 8+ years; use almost daily right at the machine. Amazing. If there was a super skinny reel attached to my reg. hose reel to wind it up with that would be plus for me to use it again.
