These worth having?
Bottom right clear thing.
renegade_cowboy
I have one. I like it. I dont use a dump tank filter, I use ladies panties hose over the main filter to the blower. I think you can get them new from jon don for $70-80 bucks new. To each his own.....
if you make a few changes so it can breath and work better it does a great job
KevinL
Kevin Leach
They do need modifying. As sold they are junk and totaly disrupt air flow. I made a better one from pvc pipe and the steel filter. What the hell is wrong with these manufacturers?
They're just a swimming pool filter that someone decided would work as a lint filter. There isn't a market for an improved for carpet cleaners version. Studebaker made a better filter, but it cost more and was bulkier, so carpet cleaners didn't want it.
GRHeacock
Is it worth having? My opinion is- yes. It keeps the junk out of the waste tank, so that does not need cleaned out as often.
Empty the filter after every job- and sometimes during a job.
Cleaning the waste tank is a lot easier when you have to.
Gary
boazcan
Gary[/quote]
I thought cleaning the waste was an annual maintenance item........... :roll:
are they worth having??
I think so.
we won't run without one.
It keeps carpet lint and chunks out of the waste tank
Use the shortest piece of hose possible from TM vac port to filter for best air flow.
I want that crap IN my waste tank, just not thru the blower.
3" dump valve to help it completely empty.
I love you, Lee, but I don't want all that lint in my tank.
I don't like piles of lint where i dump, and I SURE ain't going to strain that carpet nector coming out.
..l.T.A.
You should see my corn. Put the pantyhose "filter" over the end of the dump hose if you'd like. I don't want it for a minute blocking the airflow thru the system.
Brian R
Brian Robison
I have a regular box type filter bag thing. Gotta clean it regularly or I lose vacuum.
Some one on here said something about a filter box that doesn't lose suction untill full?
Where do I get one of those?
No joke this time, damn, I'm losin it.
Maybe this could be considered one.
Hell no, that was lame as hell.
Shut up! NO YOU SHUT UP!!!
steve frasier
we have them, 2.5" modified from Greenie
city of Portland says you must filter your waste water before it goes down the sewer
I don't use the screen, have a sock and run the nylon in the sock
Brian R
Brian Robison
were you responding to me or the post. I would be interested in getting one if they work. I need pics.
Brian Robison said:
[quote="steve frasier":12qatvlb]we have them, 2.5" modified from Greenie
were you responding to me or the post. I would be interested in getting one if they work. I need pics.[/quote:12qatvlb]
Call Greenie, Brian.
he has the modified filters.
He'll also make sure you have what ever else you need to make it compatable with "your" particular TM.
The modified filter makes a difference.
It's what we've been using for the last 6 months or more
..l.T.A.
Brian R
Brian Robison
meAt said:
Brian Robison said:
[quote="steve frasier":5ucymh0h]we have them, 2.5" modified from Greenie
..l.T.A.[/quote:5ucymh0h]
Cool thanks, I'll email him.
