thinking about adding second van. saigerizing in terms.
Scott S.
Scott
i will be trying out duel wanding the the pro 1200 soon. going to demo a unit and find out for myself. like i said i wouldnt be duel wanding all the time, and it would be mostly on commercial carpets. which doesnt allow as much airflow as cut pile. so the hg's would be higher than on cut pile.
lots of duel wand haters here. not going to buy a $35,000 machine for duel wanding sometimes. plus i would probably keep my current unit, so i could duel wand with 2 machines like saiger if i wanted to anyways.
dont knock it until you try it with a pro1200.
Reactions: Mark Saiger
Scott S.
Scott
just so you guys know i've done alot of things with my current unit that no one thought could be done. From my experiences, sapphire scientific under promises and over delivers.
Zee
Scott... You're not getting 1 hour dry times with 8flow and a machine half the size of the pro1200.
And for the 100th time : it's DUAL wanding!
DUEL is when you have 2 wands fight against each other.
Scott S.
Scott
yeah, duel, because you guys are are fighting over petty shit.
and yes i am getting awesome 1-2 hour dry times. not on commerial glue down, or on horrific restoration cleaning jobs, or when i am putting down carpet protectant, but yes on normal cut pile carpet i am. dont be jelious. i didnt say what i use, how i clean, or what i use. so chill. my setup is not the standard. and no i will not divulge the specifics.
Zee
It's ok Scott, I don't think I need a chill pill... Lol
I just pointed out some things, that I think, are true.
It's ok to be excited about your quality and your equipment.
Scott S.
Scott
im looking at the pro 1200se because of the space savings, my company does alot more then carpet cleaning and i could really use the space for other equipment and restoration equipment. i rather not pull a trailor if i can help it.
Scott S.
Scott
there are a few other units that boast duel want operation also that im looking at, but is not a must. half tempted to just buy new of what i already have. if i even do that. my unit doesnt have that many hours on it. but would love to have a helper help me knock out some big jobs with another tm and van.
We have both, big unit and multiple standard size units.
I'd much rather send multiple. More recovery, more fresh water, you can enter from separate entry points so you don't need to used extended hose length. And if one unit goes down, we still have one running.
Using $150k in equipment to clean $300 of carpet?
Yep, makes perfect sense!
You are correct Shane-- It doesn't make since to use a $150k TM to clean a $300 carpet---- You use it to make 500k a year or more. with less help.-- But A big Rig isn't for everyone-- Including Me Now--- City codes or logistics May make it difficult to use.. It would be no problem If I was back in the Suburbs.
