Thinking about making a live hose reel.
Scott S.
Scott
Anyone ever use a air line hose reel. thinking about getting a 100ft live air hose reel and using it for water.
ideas anyone?
things i want.
simplicity, well built, ease of use.
here are the ones im looking at:
This Reel: http://www.amazon.com/dp/B0037JHOCS...olid=1U9I703SLPDGZ&coliid=I9Z3J66PL0WQA&psc=1
with this hose as i have some of this air hose already and love it:
http://www.amazon.com/dp/B003TFE7YI...TF8&colid=1U9I703SLPDGZ&coliid=I30MTYYZPTPKGJ
http://www.amazon.com/dp/B004DEA3HY...TF8&colid=1U9I703SLPDGZ&coliid=I3R26EF8S2B4CA
http://www.amazon.com/PREBENA-100-F...1450445443&sr=1-20&keywords=100ft+of+air+hose
comments suggestions?
ideas anyone?
things i want.
Have not used airline hose, but have used garden hose and mounted a similar reel to the roof of one of our Butlers that did not have a live garden hose reel at the time...
It looks very much like your first amazon link....
I mounted it on a aluminum plate like Butler does and then mounted to the roof (again like Butler does)
That was over 10 years ago and that reel has been working just fine...
I got it from Windtrax at the time....
I am just curious if the smaller air hose makes it slower to fill vs a garden type hose...and get the goodyear rubber hose....in my opinion way easier to work with...
Scott S.
Scott
i was thinking about that flexzilla line because i use it for another trade and its awesome. super flexible, and not terribly expensive, and the bright color may help against trip and falls.
I've been using a hose reel like your first link with 100' air hose... Had a friend weld some flat plate to the roof of the van with studs to mount it.... Has worked ok but recently the handle broke and the o-ring on the swivel has let water leak some....
I'm looking at using a solution line hose reel to replace it... And probably put a quick disconnect with an on/off lever on half the hose because it sucks to have to disconnect when I need to dump.... I don't have a pump out on my machine....
