Thinking My Water Might be TOO Hot !!
Spurlington
Spurlino
I was farting around the van and mixing up some shit with the aux hose connected to my solution line fitting (ATM). I did some more farting around then went back in to clean. I keyed the trigger and realized I forgot to flip the valve open. Went out not thinkin cause it was cold n snowy, I flipped the valve open and then here comes the pressurized steam whipping back n forth. Nice coating across my face then a couple of passes across my opposite of elbow.
Spurlington
Spurlino
Im actually thinking of converting to propane heater. Ive had a brand new never used one sitting in the garage for the las 5 years. I was thinking of redirecting the lines from the heat exchanger into a large fresh water barrel on some type of circulation system to keep the water moderately warm before feeding it into the propane heater to give me the controlled heat I missed having back when I had a propane system.
Or keep it simple and do away with the exchanger. Although the warm feed would use less propane. Hmmmnn !!
Kellie Hiler
Kellie Hiler
I did that once and it whipped over my foot, by the time I realized it my foot was blistering and I've never removed a sneaker and sock so fast in my life!
Ever since then....I always hold that hose, even if I just started the TM.
Bob Savage
Bob Savage
Never saw a need for a hot water hose to fill something at the TM.
mirf
David Mirfin
Ouch ouch that hurts looking at it.
Shane T
Shane Tiegs
Happened to me once, water hit me in the stomach, skin came off immediately, some of the worst pain I've ever experienced. Now I won't have a open ended hose or one with on/off valve. It must have a trigger valve.
Reactions: Kellie Hiler
Charlie Lyman
Charlie Lyman
That looks painful.
I had a hose blow next to my foot once. Blistered my foot. Now that lead hose gets replaced every July.
rwcarpet
Robert Hodge
That can be a HOT mofo! The new Pro1200 has a courtesy hose that is pretty hot, but is under a very low pressure. Won't go whipping around
Spurlington
Spurlino
Arm clearing up .. I irritated it with the wanding motion .. polo shirt sleeve rubbing back n forth !!
Face Burn.JPG Face is peeling !!
Spurlington
Spurlino
I wish I could borrow one .. try before I buy !!
I used a roto vac power wand (dual head) and Dri master floor tool .. couldnt get the hang of it !!
Definitely considering the 360
I've always had a convenience hose. I do jobs with no water on at the house, and I think some folks don't like me using their sink.
mirf
David Mirfin
It seems like every time I want to use the sink there are dishes in it. Back to the truck I go.
