Have you gDescription Product Documentation and Videos
Truck Mount Power in a Portable Extractor !
13 Gal. Solution / 15 Gal. Recovery Tanks
The Eclipse has power impossible to find in other Portable Extractors, and even hard to find in many Truck Mounts.
The Eclipse offers models with 3 Vacuum Motors that produce 249" Water-Lift (almost 18" Mercury-Lift).
** New Eclipse Quad 500 Model: 4 Vacuum Motors w/ 500psi Adj. Pump. Produces around 340" Water-Lift. Monster Suction!!
The next generation of High-Powered Portable Extractors is here. CleanCraft's Eclipse is a machine like no other. Whether you are currently using another portable unit or a truck mount, you will not believe the power of this unit! Not only does the Eclipse provide power, but it also has features, components, and the look that makes this unit stand above all others.
uys seen the power out of this unit.
