Greg Cole
Recently we got a complaint from a customer/ The contractor had steam cleaned w/ truckmount his sculpted berber (since it was Nylon) and left. Yellowish stains appeared in several areas. No pets ever present. Plants throughout the house but the stains were obviously NOT anywhere near where the plants would sit.
A reservice was issue and another tech went out and performed a rinse with Chemspec Textile Rinse. Stains lightened or removed in most areas but remained in the master bedroom. The tech told me it was permanent. The guy was screaming for a refund.
I personally went out there with 2 managers and a rookie tech today to see if I could save the contractor from having to buy new carpet.
The ph paper registered a 7. I had the tech rinse with hand tool, apply 10% Citic Acid solution, dwell for 15 minutes, extracted w/ acid rinse. Stains gone. shiteatinggrin
If it had been Olefin I would understand the PH burn. BUT it was Nylon (didn't float).
I took a guess and got lucky on how to fix it. What caused this? Olefin backing?
I able to get it out? Why?
