Shane T
- Joined
- Nov 7, 2006
- Messages
- 1,663
- Name
- Shane Tiegs
That new Butler is the sweet setup!
1996 and up GM vans have an issue with the cargo side door hinges. Typically experienced with passenger vans in Northern climates where the side doors are rarely used. The hinges are exposed to the elements and the steel hinge pins rust, expand, and seize up.
This is true regarding GM side door hinges. They don't wear out per-say but freeze up, yes. I drill a hole into pin and lube it from time to time. Problem fixed.
