I'll leave my TM at home......
Carpet Cleaning
Carpet featuring Scotchgard™ Protector should stay clean 2 - 3 times longer than similar untreated carpet; providing a better appearance with less cleaning. However, when cleaning is needed, hot water extraction is the preferred method because it leaves the least amount of detergent residue.
If you choose to do it yourself, we recommend using the BISSELL® upright deep cleaning machines with the BISSELL deep cleaning formulas with Scotchgard™ Protector. And by applying a topical treatment of Scotchgard Protector, you can revitalize mill-type protection to keep your carpets looking good longer.
We'd prefer that you DO NOT use wet shampoo equipment. Shampooing may not only leave behind a soapy residue that often masks the carpet's protective finish, but it can attract and hold dirt.
Frequency of Cleaning
How often you have your carpet cleaned depends on the amount and kind of use your carpet gets, and the quality of your day-to-day maintenance. In order to maintain your Scotchgard protection 7-Year Limited Stain Warranty, your carpet needs to be hot water extraction cleaned at least once every two years by a professional carpet cleaner. Or, you can deep clean and protect your carpet and satisfy the cleaning requirement of your warranty with the BISSELL Deep Cleaning Formulas with Scotchgard Protector (see warranty for details). Use these formulas in BISSELL upright deep cleaning machines, and you'll protect your carpet and upholstery every time you deep clean.
Why Hot Water Extraction?
Hot water extraction cleaning is the best method for deep cleaning most carpets. It requires the use of a machine that sprays cleaning solution into the carpet pile. The cleaning solution attacks the soil and greasy build-up on the carpet fibers. A powerful vacuum then extracts the solution almost immediately.
For optimal protection, we recommend that Scotchgard Protector be reapplied after every hot water extraction cleaning. If you use a professional cleaner, be sure its reputable professional cleaner.
The
Institute of Inspection Cleaning and Restoration Certification (
IICRC) certifies and endorses professional cleaning, restoration and inspection firms that establish and maintain a professional atmosphere in conducting business. These certified firms can be located by calling: The
IICRC National Referral Network at (800) 835-4624. The operators will provide up to three referrals for a given postal zip code or city within the U.S. or Canada. For more information and an online referral service, explore the
IICRC web site at
www.iicrc.org. You can also call the Scotchgard Service Center at 1-800-433-3296 for assistance in selecting a professional cleaner.
