tile and grout help
Bucey
FFA?
I'm using vipor venom sprayed on dew about 15 min using spinner wand and not getting good results! Any suggestions? Thought I might use some O2? Open to suggestions!
Jim Nazarian
Jim Nazarian
Are you scrubbing with a grout brush?
If man made tile then use an acidic cleaner after the alkaline.
I prefer Oxy Blaster from Magic Wand as my Alk cleaner.
and despite what lazy cleaners tell you, scrubbing helps a lot.
and check to see if the grout has a topical sealer on it.
You find that home owner love to put clear coats down intentionally and unintentionally.
Mop n Glow is the debil
If your acid cleaner is not making the grout fizz, clean the floor with a stripper first ( may take 2 or 3 times to get it all off)
tmdry
Bill Martins
What Mikey said, plus you don't need to buy Viper it's too much $ for just an alkaline.
miksar
Mike Fent
I've been using extreme clean lately, been working great.
Bucey
FFA?
230 temp give or take, 1000 psi. Have not had this troube before, also have not done a lot either. Traffic soiling is most likely from bathroom. Some of the grout cleaned in chips and some just lighten up not very uiform. How would I stripe and what to use? I don't have a 175.
Ron lippold
mix up some o2 judson with booster or what ever you have. some peroxide from sallys will help. dwell time is key. keep it wet or you will have to start over
