Tired Sutorbuilt Blower?
N
NSCC
Can anyone tell me when a sutorbuilt blower goes bad will it lose vac first.....can it still run but at at lower vac rate?
thxs
RC
thxs
RC
they suck till they blow...you must have a hairball.....!
Duane Oxley
thxs
RC
Yes. The high points on the lobes can wear down over time. As a result, internal clearance between the lobes becomes larger and airflow slippage becomes more.
BTW... This also causes a certain amount of the airflow to recirculate inside the blower and raises the blower temperature as a result.
I
idreadnought
The amount of vacuum it loses will be so minor that you will never notice. If you took two identical machines and one had a worn blower you may notice it but over time never. I would look for tank seals, blocked filters, or a hairball in the hose somewhere.
what he sED!
Duane Oxley
I've got a Roots 36 that's about 8 years old now, that has very little suction, for the very reason I stated above.
I'll open it up tomorrow to see specifically what else may be "up", but I already know that that's the main problem...
KevinD
Kevin Dumas
I've got a Sutorbilt 4M just like your #36.
Swapped it out of a used unit and the blower won't pull over 10-12" of vac and lacks some serious CFM's.
So yes the lobes can wear out.
