adamh
My Powerclean has a 3000 psi pump, however when I go over 2000 psi the VERY small water box will run out of water faster than it can fill. I have checked everything and there is no restrictions but because the water is going through the Dema valve and other things it cuts the incoming pressure down too much. I understand the Cat pump sucks the water from the bottom of the water box so can I put quick connects on it and just hook the inlet side of the pump straight to the fresh water hose when doing high pressure cleaning? Will that do anything to the pump to have pressure on the incoming side?
thanks Adam
thanks Adam
