TM took a dump on me...EDIT...WOO HOO!!
Brian R
Little Elm, TX
Brian Robison
Not real good with the mechanical part so it's goin in on monday.
When I would pull the trigger, the pump would bog down almost shutting the engine off. When I ran out to the truck I could hear some screamin going on. Probably a belt?
I turned it off, waited 20 minutes, tried it again...same thing.
So it's down till Monday..hopefully Monday.
I didn't see any water coming out anywhere.
What do the experts say?
PA
I'm Rick James
Re: TM took a dump on me
Sounds like the flux capacitor. What kind of TM do you have?
Brian R
Little Elm, TX
Brian Robison
Jay DeLaughter said:
Maybe your blower needs to be cleaned/oiled?
I squirt the w-d everyday in the blower whole.
All oil levers were and are fine.
Hope this doesn't cost me too much.
La La Land
Re: TM took a dump on me...HELP!
Only happens when you pull the trigger mean by-pass regulator......
Brian R
Little Elm, TX
Brian Robison
Actually I mistyped, it gets worse when I pulled the trigger. If I left it alone it would bring the normal sounding TM back.
Dallas, Texas USA
Brian;
It sounds like a pump unloader problem.
Back off of the pressure adjustment to 50 PSI or so.
Does it bog at that pressure?
Then adjust it back to your normal spray pressure while triggering the wand on & off.
Poway, Ca
John LaBarbera
Brian Robison wrote:
My portable would be Bonnet cleaning now.
I couldn't stand running a portable...and I didn't even know it till I bought a TM.
Go figure.
Hi Brian,
Hope you get your TM fixed. I think Larry nailed it.
John
Walt
Brian,
Does it look like this?
If it does I'd say you might be in trouble.
SRI Cleaning
West Chester, PA
Anthony Firmani
BUT! If you had installed a flux capacitor you could go back in time to when your truckmount DID work and everything would be fine. :shock:
Brian R
Little Elm, TX
Brian Robison
yea, I get it already. ugh. :roll:
Brian R
Little Elm, TX
Brian Robison
Go figure.
Hi Brian,
John
My words coming back to bite me in the ass. You were just waiting for this huh? :lol:
I still wouldn't go back to a porty
XTREME1
Ma
Greg Crowley
when the TM is turned up does the engine bog?
I had a similar problem and it actually was 2 problems.
1. The filter in the water tank was clogging so I would lose pressure. So I pulled the filter cleaned it and put it back.
2. there is alot of bad gass going around so I put a little dry gas in. Another thing is people are running with lower fuel tanks and the crap on the bottom of the tank is getting in the fuel filter so change that regularly also. I keep a couple in the shop just in case
glenboy
MACOMB MI
GLEN
they do all suck this board shows the mentality of a carpet cleaner . worked with plenty of guys to know what quick money type work can bring in :p :p :p
Brian R
Little Elm, TX
Brian Robison
You know, now that you mention it, I didn't have a full tank, and I could have sworn I heard the vac relief. But my HG was ok at the time but the TM was all over the place and I was freaking out at the time.
Brian R
Little Elm, TX
Brian Robison
Ok, so I looked at the inside and nothing to see out of the ordinary.
Yea, like I know what I am looking at.
I started it up and did some spray and suck and nothing went wrong.
When I was using it and it started screwing up, I had the pressure at about 900psi with turbo hybrid. I have always ran it at that with no problems.
Maybe it got too hot? it was hot yesterday.
Maybe there was a leak somewhere and caused the belts to squeel and lose power?
I am afraid to use it tomorrow and I have jobs. I have already lost a little by 50/50 with a local guy.
I will take it to the shop tomorrow either way.
Stay tuned.
N GA
BradFenstermaker
Sounds like you need to check your pump belt tightness. Cleaning tile puts alot more strain on the belt. May just need a belt.
Brian R
Little Elm, TX
Brian Robison
God I hope so.
I need to make some money tomorrow
Brian R
Little Elm, TX
Brian Robison
Ok,
So it ended up just being a hose that was dripping onto the belts and the belts gott limp and chewed.
Thank god it didn't cost me too much. I am up and running today.
Thanks everyone for you help. I will have to go back to through the thread to see who was right. lol.
Brian R
Little Elm, TX
Brian Robison
I think Brad came closest.
Brian R
Little Elm, TX
Brian Robison
Ahhh the memories. lol
I kinda miss it sometimes....sorta.
I often day dream about running a small truck on some easy high end work.
Then of course I come to my senses. lmao.
I wouldn't mind starting a low moisture route. Low dollars to start and I could pick and choose who to clean.
I did own Chem-Drys years ago in my other life. I could make it happen.
"Priority the Dry Authority" Whattyathink?
You never know.
Brian R
Little Elm, TX
Brian Robison
I remember doing a hot seat in the Greenhorn room when I jumped off the truck. People were giving me hell ....and of course still do.
Gotta love this place.
dgargan
This sucks
I had to read almost all the way to the bottom to find out this was an old thread. I was wondering why Brian was back on the truck?
-JB-
here
JB
Brian between you n Crowley, is there anything you haven't tried?
Brian R
Little Elm, TX
Brian Robison
I was a carpet cleaner for 25 + years (counting childhood) I've done some marketing stuff now and I help Jen with Mary Kay.
I've done Herbalife...which I am thinking of jumping into again. Just another "upsale" to the demo that I sell to now.
And it's good for you.
