TNT back fire-Kohler 20 horse
richard
Richard Weedman
Ever time I start the machine, after the first job of the day, the thing back fires when starting. Obviously loading up at previous jobs shut down. I always run it at idle for a few minutes before turning it off. Any ideas? Carb or ignition??
I have a kawasaki water cooled motor and it would always backfires on me too while idling down. Scares the sh!t out of you and the customer too. I got to the point to turn the ball valve in the closed position while the machine is idling. It stops pumping gas into the carb. Hope that helps you. It works for me.
KevinD
Kevin Dumas
Better send out a service advisory when you find the fix for the problem.
Sorry, couldn't resist.
vincent
Vincent Sapp
Try a new air filter and a set of plugs.
handdi
Randy
pull your vac hose off of the machine before ya take it down to an idle
and a new set of plugs prob wo'nt hurt either
richard
Richard Weedman
I always run at idle w/o hoses attached. I put new plugs and air filteron - we'll see.
Danny Strickland
i thought those engines were supposed to be run to half throttle and then be shut down??? something to do with fuel??? sounds like the carb has some fuel left in it and thus explodes upon cranking???
call Butler and see if a service advisory has been issued!!! :mrgreen:
